Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories
View Poll Results: Are You Going to Roll Your Own CDI?
No, too complicated and difficult. 26 24.07%
Yes, but only one, for my own MB. 36 33.33%
Yes, a few for my own use. 37 34.26%
Yes, many, I'm gonna sell 'em! 9 8.33%
Voters: 108. You may not vote on this poll
Old 03-10-2016, 02:47 AM
thecoolsundar thecoolsundar is offline
Default Re: Roll Your Own CDI
Has anyone disassembled the rotor? I'm curious as to what kind of magnets they use and how the laminated stack looks on the inside
Old 04-07-2016, 04:38 AM
Ahmedy's Avatar
Ahmedy Ahmedy is offline
Hi guys. I've got a problem. I've built Rohmell's cdi twice now and I tried building the jag one also. I'm not getting spark from either. Then when I hook up the original Cdi it works with no problem. Could it be the Chinese coil I'm using or could it be that the original stator coil isn't producing enough volts.
Old 09-08-2016, 04:09 PM
nyemi nyemi is offline
Welcome everyone.
Circuit your opinion?
Resistance(P1) to change the ignition timing.
Your test circuit.
Regards nyemi
Postscript:I optimize circuit.Sorry.
Old 11-17-2016, 02:22 PM
humanj humanj is offline
Hi Rohmell
Please help me out, I noticed in the first circuit you posted a 33 Ohm resitor was present. The later circuits it is not present. At first I tried the circuit with the 33 Ohm resitor but no spark. Eventually I came right after removing it. Is the purpose of this resistor the limiting of current on the Gate Resitors?
I must say this circuit performs very well givven its simplicity. I used a Yamaha Generator Ignition Coil.
Thanks for your effort!!
Old 11-17-2016, 02:41 PM
Hi Toad
You can use a Yamaha Generator coil -- Yamaha High Voltage Set ET950 -- Works well.
In the orginal Circuit you added another capacitor but you did not include the capacitance value. I would also like to experiment, please supply the vallue.
The orginal circuit works well I must say.
Old 01-26-2017, 06:47 PM
rohmell's Avatar
rohmell rohmell is offline
Another CDI schematic.
Old 02-01-2017, 01:56 AM
Attachment 84786
Hi rohmell
Operation description, help:thyristor adjustable phase cutting.
Link:http://www.allaboutcircuits.com/text...rectifier-scr/
Factory-circuit revised ideas:
MotorBicycling.com
