Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 01-14-2012, 10:15 PM
charliechaindrive.'s Avatar
charliechaindrive. charliechaindrive. is offline
Default Re: List of motorized bicycle gearboxes
Oh, huh thanks. Do they make a internal gearbox for 2 smokers???
if you think you dont need it, wait two weeks. you'l prove yourself wrong 9 times outta 10
userix userix is offline
Are these hoot gearboxes notorious for breaking down fast?
Old 01-14-2012, 10:38 PM
MaxPower's Avatar
MaxPower MaxPower is offline
If you can find a an engine with the same bolt hole pattern and clutch diameter as the gearbox then yes.
Max Power is my hero
Old 01-14-2012, 10:39 PM
MaxPower's Avatar
That's what I've heard too but I can't say so first hand.
Old 01-14-2012, 10:41 PM
Ic, but couldent you run the chain from the motor to the shaft of the box via chain? To look like a board tracker?
Old 01-14-2012, 10:57 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
I like Gareth's ra drive!
What gear set did you use as a base for your project?
...something that might be available here???
Best
rc
Old 08-12-2012, 08:09 AM
N057828 N057828 is offline
http://www.ebay.com/itm/49cc-X1-X2-N...f4527e&vxp=mtr
Will this fit Hua Sheng 4stroke 142f I'm sure but the sprocket is wrong as I need one to fit 415 chain??
Old 03-07-2013, 12:12 PM
sylarbrodie sylarbrodie is offline
just ordered my qmatic. hopefully no more repairs!!!!
Old 05-24-2016, 09:45 PM
mezzenger mezzenger is offline
Hey Guys. It is 2016. Perhaps someone in the know could post updated information?
Old 05-24-2016, 10:06 PM
MotorbikeMike's Avatar
MotorbikeMike MotorbikeMike is offline
Dealer
Hi mezzenger, I am not in tune with everything being made, BUT I do know that EZMotorbike makes the Q-matic, and the Pacesetter drives especially to fit HauSheng and Honda GX50H 5/8 keyed shaft engines, also the internal clutch model of the Hau Sheng (with special adapter we make).
The Pacesetter is also available drilled to bolt right on to the Harbor Freight 79cc Greyhound, and the 99cc predator models.
It is adaptable to many other engines, but these are the patterns I am currently aware of. I am currently interested in mounting one to a 3.5 HP Briggs and Stratton Vertical tho I am not sure how I will bolt on to the old engines that I currently have.
I hope this helps answer your question.
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the EZM Q-Matic Products
08 Racer and NEW Model 10 production bikes
Whizzer, Pacesetter Products, Starfire, and SkyHawk
MotorBicycling.com
