Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-26-2016, 07:14 PM
Tom from Rubicon Tom from Rubicon is offline
Default Re: 79cc Sportsman Flyer build
Had to make a shim of 1/4"6061-T6 and still have to remove metal from a corner of the Q-matic transmission clutch side bracket to clear the frame hanger tube. Makes me wonder what I was thinking except to reduce the complexity of the Sportsman Flyer transmission. It will be solved if I have to machine a whole new instead of the aluminum extrusion which has marginal strength for it’s designed application.
Tom from Rubicon WI
Old 10-15-2016, 07:14 PM
Q-matic inner transfer case bracket modified, last week. Still trying to post photos.
Some forums are easy this one not so much, or I am lazy and just don't want to jump the hoops. Snow will soon be in the forecast here, and I have a ton of irons on the fire.
Not bad for a guy pushing 66 years young.
Tom from Rubicon
Old 01-04-2017, 07:15 PM
Q-matic transmission canceled from this project. If I made it work, the transmission would be at an angle for the chain to clear the chain stay which was esthetically wrong. At least to me. Contacted Pat Dolan, and ordered his Reduction drive system, and Bully clutch. Sorry, but a Q-matic and a drop loop frame are a less than perfect combination. So I end this non kit thread for the above reasons. Should anyone like to prove me wrong I would be delighted.
As I have a Q-matic transmission in need of a purpose.
Old 01-04-2017, 08:13 PM
MotoMagz's Avatar
MotoMagz MotoMagz is offline
I ain't provin anything. Good choice to go with Pats set up which will look clean? I think you might have possibly been able to use a tensioner to help clear chain?
MotoMagz
Old 01-05-2017, 06:47 PM
MotoMagz
My calculation was a twenty degree rise in the out put end of the transmission would provide the necessary clearance to make the Q-matic work. But esthetically a Flyer is not a Whizzer. Pat has got intouch with me. Things will soon be put to right.
Thanks for the reply.
Old 01-17-2017, 06:37 PM
My last email to Pat was this last Friday 1/13/17 to finalize my order of needed parts.
SPORTSMAN PEDAL CRANK ASSEMBLY WITH REDUCTION HUB
SPORTSMAN FLYER CENTRIFUGAL CLUTCH BY BULLY
SPORTSMAN HEAVY DUTY SPROCKET ADAPTER
Same day I called Worksman and ordered their 4136A 26X2.125 wheel, which should be here any day now.
Old 01-17-2017, 07:13 PM
http://s481.photobucket.com/user/trp...ml?sort=2&o=39
Lousy photo. Will try again soon.
MotorBicycling.com
