Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 10-11-2016, 06:48 PM
machinegun4784's Avatar
machinegun4784 machinegun4784 is offline
Default Can't find sprocket
I'm looking for an inch and a half wide sprocket with a large inner bore. It needs to be an inch wide inside. I need a #25 steel sprocket. I tried drilling one out and not only does it take forever, it's not centered. Anyone know where I can get one or somewhere to get custom sprockets?
Motors make you go!!
Old 10-12-2016, 09:08 AM
Venice Motor Bikes's Avatar
Default Re: Can't find sprocket
if you can get another sprocket?, any machine shop should be able to drill the hole perfectly centered for you.
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
MotorBicycling.com
