Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycles engine
Old 01-28-2016, 02:14 PM
Mouse Mouse is offline
Default Big jugs
I have a 48cc grubee Skyhawk 2 stroke can I change the jug and piston to a 66/80cc?
Old 01-28-2016, 04:24 PM
ckangaroo70's Avatar
ckangaroo70 ckangaroo70 is offline
Default Re: Big jugs
Large jugs? Sorry...was expecting to see something different here. lol
Really don't know why you couldn't go with the larger displacement jug. I think the lower ends are basicly the same on most all the china girls and I would assume the cranks the same, but perhaps more research is in order
3rd Annual Midwest Scarecrow Run/June 10 2017
http://motorbicycling.com/showthread.php?t=61380
Old 01-28-2016, 07:58 PM
Greg58's Avatar
Greg58 Greg58 is offline
The stud spacing is not the same, I don't have the specs but I do know my 48cc's and the one 66cc are different.
Your results may not be the same,Greg
Old 02-04-2016, 10:18 PM
sbest's Avatar
sbest sbest is offline
6mm studs at 42mm for the 48cc.
8mm studs at 45mm for the 66cc.
Steve
Old 01-28-2016, 08:34 PM
Is there any one who could help me with finding a faster reliable motor ? I'd like to go35-45mph without going wide open on the throttle. And can I modify the existing motor to do that?
Old 01-28-2016, 09:00 PM
Greg58's Avatar
There are a lot of modifications that will increase speed, porting done right is one. Adding a expansion chamber is another, changing rear sprockets from a stock 44t to something with less teeth will increase top speed but cuts hill climbing ability. If you do upgrades do one thing at a time, that way you'll know if what you did helped or hurt performance.
Old 01-28-2016, 09:32 PM
What about a jackshaft and hooking it into the existing bike gears?
Old 01-29-2016, 05:07 AM
Greg58's Avatar
Yes a jackshaft kit will help, here in Georgia a multi-speed moped is not legal so you might want to check your state laws.
Old 01-30-2016, 02:15 PM
Chaz's Avatar
Chaz Chaz is offline
Mouse, getting a bike to do those speeds is not a problem. Doing those speeds safely is the real issue. You are asking for motorcycle performance from a bicycle, so that bike and all of it's components must be up to the task. I'm guessing that about 75% of your budget and efforts should go into building a solid bicycle foundation to bring it up to manufactured moped standards.
Just a chimp with a gun and an idea we should be free to ride our machines without gettin hassled by the Man.
Old 02-04-2016, 03:01 PM
Got a grinding feel in bike when motor is engaged. Bearing? Time to rebuild?
MotorBicycling.com
