ok guys i have a cns v3 carb and i have been running a brigs air filter retro fitted to it and all was good, a lil four stroking across the board but good tunning over all.
i recently bought a sbp 90 deg performance air filter
i fuelled up and oiled the bike
installed a new fuel filter
installed the new air filter
let the bike sit for the weekend
well when i got back i took her out for a ride to work and with the new performance filter on it seems like its way too lean and it bogs after 1/2 or 3/4 throttle and has no power up hills and i couldnt figure out what was wrong ! there was no way a simple filter swap would make her run this lean !!!
so i pulled the carb and manifoled thinking it was an air leak or clogged main jet and rebuilt thee carb and installed new gaskets and made shure the carb was seated to the manifold at the clamp nice and tight !
well the same thing happend ! bogging at 1/2 to WOT and no power just like someone cuts of the fuel when i pass 1/2 throttle !
now i am stumped cause i know there is no air leak and the carb was jetted slightly ritch before on porpouse when the other filter was on and it ran great so why does it run so lean and have no power now that i put a 90 deg SBP filter on ?,
thats when it hit me ... well i am running 13:1 comp and require high octain gas as fuel and i filled up at a coner station .... mabey i got ripped off and given 87 oct instead of 93 ! that would explain the motor change of tone and the loss of power the higher up the rpm range i go ! so i drain all the gas and drain the carb and refill the tank with high octaine 50:1 premix fuel from the hardware so i know its good ! TRUE FUEL 50:1 92 oct no ethanol. then i make shure all the fuel is flowing out the petcoxck fast enough and then check to see if it flows out the bowl fast enough and shure as heck it does there is no restriction there ether !
now with the new fuel 92 oct 50:1 and shure there are no air leaks i take her out again with the SB filter on and guess what ??? the same simptoms !!!
now i try my hand at jetting thinking the new filter may flow too mutch air and be leanning it out when the main jet comes into play so i ream it out from .69mm to .74mm and take it out ... well it got slightly better, now it bogs at 3/4 throttle to WOT with the air filter on and still zero power up hills of any kind !!!
well i just swapped back to the old dirty orange brigs air filter and my god what a differance !!! the bike has tons of power and can rip all the way up to rpm's i am not willing to take her to yet LOL and she blast up hills without a single inkling of power loss !!! as a matter of fact she is more powerfull than before !!! i guess because of the rejetting to a .74mm !!! there is a verry slight 4 stroking when not under load but breaks clean into a good 2 stroke when throttled.
when i put the sbp 90 deg filter back on again ...... booom no power and a sharper raspier engine tone and she keeps cutting out/bogging down at around 1/2 or 3/4 throttle !
whats up here ? should i go even bigger on the main jet and see if that helps or should i just run the filter i know works ? why would the 90 deg SBP filter cause sutch a performance loss ?
