so i tried everything to get the clutch to stop slipping cleaned it, tightened the flower nut, tightened the tension spring. but couldn't get it to stop slipping there's plenty of clutch pad left its not worn out motors brand new.
so i decided to look at the flower nut and where it screws on. i took a file to it and took off about a millimeter of metal off the bottom of the flower nut where it was hitting the clutch shaft and not allowing it to move fully. seems to have solved my problem of it not garbing looked like it wasn't fully machined down and there was a lip left that was causing the problem.
but its still slipping while going down the road so i think i need to take a bit more off off the flower nut to make it sit right Ive got it in as far as it will tighten so my only option is to modify it.
has anyone else ran into this problem?
