Here is my issue: I pedal down the street, release the clutch, engine starts. Then I give it gas, the engine revs a little, but then it just dies out.
To me, it sounds just like a weed eater if the choke isn't adjusted properly. I've tried tightening the cable that connects to the throttle thinking maybe I'm just not pulling it tight enough when I twist the throttle, but that doesn't help. I don't know what the problem is.
I bought this kit about 6 months ago, and it has had this problem from the beginning. I lost motivation to try to fix it, so my bike has just been sitting there. But now I'd like to fix it. Any ideas???
I've applied the rubber silcon sealant around key areas where air leaks might affect the engine power, but that hasn't helped. Maybe I didn't apply the sealant everywhere I should have. And yes, there's gas in the tank.
The fuel was mixed with 18:1 ratio, which was the recommended amount for the initial ride. Could that be my problem??
This is my kit:
GRUBEE SkyHawk GT5 66cc/80cc Slant Head Bike Motor Kit (Standard Finish)
This is my kit:
