OK, so i finally finished installing the shift kit and 66cc grubee on my searcher. First of all, i have a question.
1. on the carb that came with the kit there is a lever for the gas, and then there is a lever on the end of the gas tank. I know where the "on" and "off" or on the tank lever, but i am not sure about the lever on the carb...please help.
Anyways, after i finished the build, i added gas mixture to the tank and choked it and everything you need to do before you attempt starting a motor. I get a little speed and start the engine. As soon as the engine starts, in revs real high and it does not idle. When i stop, the engine dies. If i try to rev with the throttle, nothing happens, but if i give it all it has for a couple of seconds, it starts to rev.
I tryed messing with the idle screw but it does not help....
Thanks for your help,
Roel
Roel
