we got this muti tool lathe/milling device at work
as a project in how to use it we knocked out a rear sprocket centering tool from a piece of 1.5" HDPE plastic that was lying around
OD 1.45" center hole .375" (Fits bike axle and rear sprocket supplied with kit)
inserted in hole over axle- as i tightened on the sprocket, continuously checked the fit of the centering tool
seems to have worked great...
This piece does not prevent the sprocket from moving, it is just a measuring device. I repeatedly remove it during the process and if it binds i know the sprocket has moved out of concentricity...
