Acceleration problems.....need advice
So now im startin to pull my hair out! Im not a complete newb with two-strokes or anything and im very mechanically inclined, but im having an odd problem with tuning my carb that I cant for the life of me figure out......
It all started when I put on my FMF exhaust. Basically its a straight pipe back to an FMF powercoreII silencer. My carb has never been perfect, but always manageable untill this.
HERES THE ISSUE - If I ride it normally it will start to bog out at about 1/2 throttle. This problem is fixed by putting the choke half on, and then it runs PERFECT (I know just need to richen the mix as its getting to much air in the mix right?) However with the choke on, it will completely stop accellerating at 46 KM/H (26ish MPH). Now if I take the choke OFF when it dies out at this speed, it runs perfect again and pulls all the way up to 32 MPH like it used to.
I just cant be taking my hand off the bars every few mins to turn the choke on and off when im riding to keep this thing riding good. I figured these symptoms mean that I just need to richen up the mix up to 3/4 throttle, so I dropped the needle to the lowest setting.....still does it. And because at high speed it runs great with the choke off, my main jet is fine.......(I have tried the carb needle on all settings to no avail)
HELP!!!! Any suggestions would be appreciated. Only mods are an NGK plug, the exhaust and a free flow intake
