heres the drive for my 4 stroke build,
not sure what you mean. if i used gears from the gear box to the 3 speed hub that would reverse the direction. i'm using the 3 speed hub to get more reduction than the 3 to 1 box offers plus getting 3 speeds and no need for a free wheeling crank set. i should have it ready for a test drive in a few days.CAM the chain that drives the wheel, Why didnt you go straight to the shaft with a drive gear? It seems it would be simpler and less moving parts plus less loss of power. What was your thinking on this? Im thinking you did this for strength and to cure the shifting of parts maybe as you said, was this the sole reason?
