Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Whizzer Motorized Bicycles
Whizzer Motorized Bicycles Whizzer bicycles are still produced today and are one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today
Old 12-19-2016, 02:43 PM
msrfan msrfan is offline
Default Re: H Whizzer on Schwinn-Older Restoration
Thanks jb, yes it was a nice restoration with quality parts and paint. I know what you mean about those little clutch dogs. The pin is not easy to deal with. Did you use the spacing washer to make them line up with the inside slots on the plate?
Old 12-19-2016, 07:37 PM
jbcruisin's Avatar
jbcruisin jbcruisin is offline
Originally Posted by racie35 View Post
I'm curious how you were able to assemble it and have one of those fall out on the floor. Was it ever in there? Or did you park your bike over your mistake?
I should have said a piece of the dog broke off.
EZ Motorbike Dealer
http://ezmlebanon.blogspot.com/2009/...f-lebanon.html
Old 01-04-2017, 08:33 PM
I took the crank and rod to my Whizzer parts supplier to get them welded up and machined. While I'm waiting I decided to check out his automatic clutch. Overall it's in good shape. Needs cleaning, new bearings and an engaging dog with pin.
The arm has a chunk out of it. Maybe it was ground out for clearance. I'll find out after cleaning it up a bit.
The magneto coil will be getting a new spark plug wire. Get rid of the condenser in favor of a point eliminator. Then replace the plug cap with one that's more Whizzer.
The carb is pretty nasty inside. It should clean up nicely. The spring and ball that holds tension on the choke shaft is missing. I think I have those.
The belt guard had a couple of cracks and bends, but is still presentable.
Old 01-08-2017, 08:51 PM
I was able to purchase a correct dipstick. And the chunk out of the clutch arm was ground out. Ray says he sees that a lot on clamp in motors to clear the top mount. So I'll smooth it out and make it looks like it belongs.
I got all the clutch pieces cleaned up and ready to reassemble with new bearings and replacement engaging dogs. May need a new felt washer. Still need to rivet the linings back on. They are good and thick.
John Koehnke brought my rebuilt crank and rod to Donut Derelicts, and I didn't need to drive to Orange and pick them up. Came out real nice at .030. The original crank wouldn't clean up even at .050 so I used one of my other used ones. Have to figure out what to charge for an outright crank (no core trade in). The rod got it's dipper repaired and Fred Koehnke said it was bent also, so he straightened it and made sure the small end bushing was the right size.
Old 01-08-2017, 08:54 PM
I got to hang out with Ray (mason man) most of Saturday and talk Whizzers. Had a great time. He's a wealth of info and just a fun guy.
Old 01-09-2017, 05:00 PM
Today I finished cleaning all the carb pieces. I will assemble after I get a new cover gasket.
I also repaired the plug wire and soldered a silicone cover wire that goes to the points/eliminator. The owner is a hot rodder from way back and I know he'll appreciate the Rajah plug clip.
Old 01-09-2017, 11:43 PM
mason_man mason_man is offline
Thanks Dale.
Carburetor looks brand new! Auto clutch does too,as does the mag.
Looking forward to seeing the motor running. I luv the sound of them.
Ray
Old 01-10-2017, 11:19 PM
Couldn't find a gasket soon enough, so I made one.
The carb went together smoothly. The only issue is the fuel mixture valve has an o ring, but my buddy Dan made a punch for his Tillotson to make a leather packing. That should finish it.
Old 01-20-2017, 08:30 PM
I cleaned up a bunch more parts. Next I'll paint the cylinder, lap and install the valves and chase all the threads to make sure it goes together with the correct torque specs. Maybe file all the extra flashing off between the fins to give it a nicer look. The head has a few broken fins, so I'll Dremel the rough edges and shine it up just a bit while trying to keep the original look.
MotorBicycling.com
