Lots of problems lately, including the fact that my modem just crashed momentarily, and this is the second time I am writing this!
The first problem I had, I fixed, but I'l tell anyways; the spring on the butterfly valve broke, and I lost all throttle control, and to stop, I had to shut the engine off; I was still about 2 miles from my Blacksmithing class, so I decided to pedal, and pull start the engine, and when I need to brake, I would just shut the engine off. Was able to fix the spring, by using needle nose pliers to rebend the spring at the end that broke, and wrap around , and now the throttle action works much better than it ever has.
New problem ... was riding at full throttle, as I always do, and heard a loud noise, and the engine died. I pulled over, and the only thing that I could see, was a nut was missing off of the pull start mechanism. I tried to pull start it, and nothing, wouldn't even turn the engine over, and it felt like there was no tension/resistance in the pull cord.
I pulled it apart, and couldn't see anything obvious, I also checked/cleaned the spark plug just in case, but nothing.
I called Terry Blow at Blow By U cycles, and he said to pull the engine apart and it was probably the driveshaft?, at least I think that is what he said; i'm tired, and just had a beer.
Is there anything else I should check before pulling the rest of the engine apart, already pulled off the magneto w/my gear puller, before I realized I have to take half of the engine off.
Now, part of my question is whether you have any suggestions before I pull the engine apart (it did sound like something broke). Has anybody else heard of this? Oh, and the magneto would turn freely in both directions w/out any tension except when the magnets crossed paths (if this means anything).
Thanks, sorry for rambling.
