trouble with rear sprocket/chain
Venice Motor Bikes
Mar 20, 2008
7,271
1,810
Los Angeles, CA.
Looks like I won't have to bend the frame at all. The problem was that the bolts holding the tensioner to the frame were stripped so I couldn't keep them tight. Every time they'd loosen up, the tensioner moved and caused the chain to leave the sprocket.
I love how most people can eventually answer their own questions if they just keep trying to find the real problem. :crash:
(Now, aren't you glad you didn't bend your frame?)
brucemg51
157
You're right about answering your own questions if you look hard enough for the answer.
Being an old motorcycle mechanic, I've bent a lot of frames. It's very common practice to heat a section of a frame with a torch and modify it. I've also cut off sections of frames, bolted frame sections together and brazed or welded frame sections. On my first MB build, I was putting a multi-sprocketed wheel in place of the original coaster brake wheel. I discovered that the rear fork had to be wider in order to accept the new wheel. I simply heated some key sections of the frame with a MAPP torch and applied the right pressure to widen the space between the members of the rear for. No problemo. The new wheel fit just fine. Of course, it's something I'd rather not have to do, but really, it ain't a big deal at all.
brucemg51
157
