i going to make a friction drive chainsaw bike. I had a question about the pullstart. Will it still work to start the chainsaw bike
I have a KS bike machine motor that. Was made back in the 60's it has a clutch, has about 3" . Sure is nice to pull up to a stop without having to do anything,just hit the gas and go ...........CurtHas anyone ever successfully used the clutch with a friction drive weedwacker or chainsaw? I mean, I know it will work, but for how long? Once the cent clutch engages, is it strong enough to drive a man on a bike without slipping and burning up?
On my builds, the pull start is removed once I know the motor is all sorted out. Bump start from then on. Then I use a motor lift system to engage/disengage friction drive. I must admit, though, that the clutch on my Echo weedwacker looks pretty stout. About 3 inch diameter with beefy-looking shoes. Still don't plan to use clutch in a FD build.
any chance for a pic? maybe some close ups of how the motor is mounted and the drive system?I have a KS bike machine motor that. Was made back in the 60's it has a clutch, has about 3" . Sure is nice to pull up to a stop without having to do anything,just hit the gas and go ...........Curt
I am on the road traveling and all my ifo is at my home computer. But it is the same as a pocket bike engine with a clutch, infact if i can't get my motor to run right this summer i will use the pocket bike engine. It is set up the same way as a weed eater with bearing in the houseing and a bearing on the outer end. try and google a ' K&S Bike Machine Motor and see what you find. Dax,and Staton have a simular setup but the K&S has a better lift lever all you do is reach back and move the lever with a shift knob on it and it lifts the motor for pedaling.any chance for a pic? maybe some close ups of how the motor is mounted and the drive system?
