Turn the gas on, wait a few seconds it starts pouring out the air box. Is that a common problem? - or is the extension piece I welded on not allowing the gas to flow into the motor because it's pointing down hill towards the air box?
I'm thinking since it's not pointing where gas would flow into the engine that it's backing up in the carb and then going out the air intake. But then I'm thinking that even if that was the case would on a normal install eventually the motor would fill with gas, back up into the carb and go out the intake.
I moved the clip on the needle up. Other than that haven't down anything internally.
