My Ultimate Motorized Bicycle Wheel Cost $689.00
dmaddox459
10
SF Bay Area
I don't post often but I am a long time lurker! After building a number of the El-cheapo China Girl Bikes with used bikes, wheels, rag joints etc...I decided to build my ultimate motorized bike. The Ultimate MB needs The Ultimate MB Wheel, right? So I decided to sell a few other "toys" and fund this build properly. Sold some computers, shotguns and the wife's dog. (that ran away)
The Hub, Adapter and Sprocket
I watch Pat Dolan's Sportsman Flyer Blog pretty closely and ever since he first posted about his Heavy Duty Hub I wanted one with the cool billet adapter and split sprocket. Pat's hubs are pretty awesome with 80mm drum brakes and threads for a pedal side freewheel. They're modified Moped Hubs so I know they'll brake pretty good. It has a 14mm axle with sealed bearings. The rear dropout width is 135mm and the over all axle length is 175mm. Pat had one so I ordered it with an adapter, 58 tooth split sprocket and Shimano MX30 BMX 18 tooth pedal side free wheel. Total cost with CA Tax and Shipping was $225.00.
The Rim, Spokes and Build
My goal is to build something a little different and even a little exotic. After a lot of research I decided to go with an Excel Takasago 21 X 1.60 motorcycle rim. These are very high quality rims used by a lot of Japanese motorcycle builders and actually come stock on some motorcycles.
If you aren't aware, bicycle tires are measured in overall diameter and motorcycle tires are measured in bead diameter like a car. This means a modern 26 inch bicycle tire is actually 26 inches from outside tread to outside tread with the standard 26 inch ISO 559 rim actually being 22 inches in diameter.
I'm putting an Avon Venom 80/90-21 which ends up with an overall diameter of 27.1 inches and 3.2 inches wide. When placed side by side next to my China Girl with 26 X 2.25 Kenda Flames they are almost identical in size with the Avon being an inch wider.
I called The Wheel Master (the real one) in Auburn, WA and it turns out he is an Excel distributor. He had an Excel 21 X 1.60 Model ICS408 in stock. For $350.00 he would build it with 36 stainless steel motorcycle spokes and nipples, supply the Excel rim, life time warranty and ship it back. I boxed up the hub, sent it off and got it back in a week! His reputation is well earned as this wheel is simply awesome.
The Tire
Avon Venom AM41 80/90-21
H Rated (125 MPH)
Cost $104.00 shipped
Total cost for the complete wheel was $689.00. It might seem a little crazy but I'm planning on keeping this bike for a while and riding it on a daily basis to work. In San Francisco you can ride a bike year round and the cops are really cool with MB's as long as they are plated and you wear a DOT helmet.
The Overall Plan
The front wheel is a NOS Honda CB110 hub with an Excel 21 X 1.20 I special ordered from Excel mounted with a matching Avon 60/90-21 H rated tire up front. The Wheel Master will build this one too. The CB110 hub has massive 100mm brakes and the stopping power is phenomenal. A friend has one of these and it stops better than any disc brake bicycle setup I've seen.
The frame is an actual 1937 Autocycle being modified with widened rear drop outs and a drop down tube for a killer Board Tracker look by an air craft shop at SFO. They are also building a custom contoured in-frame tank. I wanted one of the Sportsman Flyer Frames but Pat said he is almost a year out on builds. Bummer
The engine is a Honda GX160 with electric start and a 50W electric charging coil. It's out being blue printed, balanced, ported/polished, mild performance mods and dyno'd. I will strip off all the shrouding and mount it so the cylinder is vertical. A 24mm Mikuni with a custom made billet intake will do the trick. I want it to run silk smooth and be reliable. BTW that same friend has run a GX160 with literally thousands of miles under abusive conditions here in San Francisco with no shrouding and has had zero problems. Never over heats.
I haven't decided if I will go with a jack shaft or a torque converter. Either way, the 58 tooth sprocket will work great.
I've included some pics and I'll update this as I progress.
Dan
**I have no affiliation whatsoever with Sportsman Flyer or The Wheel Master, just a happy customer of both. I have never met either but Pat Dolan has offered to let me test drive a Sportsman 200 as I only live about 30 miles away. Will ride my build down there when I get it finished.
Wheel with adapter/split sprocket
Without Adapter or Sprocket, ruler is 6 inches
Cross Section
Spokes are massive bigger than any bicycle spokes
Sprocket
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
24
Ridin' inSane Diego, CA.
Scotto
Nice looking wheel, going to do something similar to my China Girls when I get this finished.
Dan
Thanks Dan.....likewise. The current rims on my 212cc are Atomlabs Pimplites laced to 36h Surly disc hubs with 12GA. stainless steel spokes and nips. 26" Maxxis hookworms with Intense downhilubes.
The new wheels are Halo SAS rims 48h rear disc hub (Halo spindoctor) and 36h front disc hub (Halo spnoctor) white w/black spokes and nips.
24" Maxxis Hookworms with Maxxis DH tubes. Running 50-60psi nitrogen in all tires.
.wee.
culvercityclassic
3,115
177
Culver City, Ca
Dan... Those are great looking wheels. I look at those rims every time I go to the swap-meet and just drool. It’s nice to see that you have come up with a set that will work. I noticed how wide they are, will the chain clear the tire on the drive side? This just may be the direction I will follow with my current build. Great wheel set...
On another note: I run the GC160 on my BTR and it runs great, you will be pleased. I am curious to know who is rebuilding the motor for you...I have a contact for a cam regrind if needed.
Contact me if you have any questions on the drive system...
rustycase
Gutter Rider
May 26, 2011
2,746
Left coast
Dan, everything about your wheel looks awesome!
I certainly wish I could afford something like that.
No doubt it will provide service for a long time.
rc
dmaddox459
10
SF Bay Area
Thanks guys,
I haven't built the front wheel yet, waiting on the rim to arrive. It's going to be a Honda CB110 hub with 100mm brakes laced to an Excel 21.
@CulverCityClassics
The chain clears great.
Will post more when I get it in along with tires mounted.
scotto-
Jun 3, 2010
6,505
24
Hey Dan, just got my new front wheel today......$268 without, rim strip, tire, rotor and tube. I'm not sure if we'd be able to use the set-up you're building at our races. They say no motorcycle tires (yeah, whatevers) so that's why I'm sticking to high quality bicycle stuff. Your wheel set is well thought out and as strong as any I have seen used on bikes. Great job on getting your ultimate wheels, as they truly are and good luck on yer build! ;)
scotto-
dnut
sportscarpat
Jun 25, 2009
1,839
471
83
california
Beautiful wheel Dan. Can't wait to see the front one. Were working on three sets right now for some very powerful bikes I have in the works. The whole reason to go this direction is for true speed rated tires. More light weight motorcycle than heavyduty bicycle. I was running just a hair under 60 mph just the other day on a set of Simplex tires. They are alright, but getting them to seat perfect on the bicycle rims is difficult. I get the bicycle rims perfectly trued and still get a slight wobble in the tires when checking on the truing stand. I bet those motorcycle tires will spin nice and true.
