Im asking for answere to the old valve cover hose that originally goes back into the original air filter. Im going with a pz-19 carb with a k&n type filter so I have to do something. Ive seen people drill holes into the block in the case and tap a hole for a hose fitting. Ive also heard something about a catch can for the oil to drip into. Ive seen people use the hose for pulse pumps too. NOTE: Im not going to be using a puls pump-just gravity. Can you all chime in with the best setups and what not to do?
1. Whats better? Catch can or into the block? Will aiming it at the ground spit oil everywhere?
2. Has anyone combined a catch can and into the block? Like a filter before it goes in the case to insure clean air back in?
3. Is thhis method bad for your engine?
Thanks. Happy Saturday.
