I made this mount for a Harbor Freight 79cc engine we mounted in a Schwinn Corvette frame but it will work for other engines as well. This mount is not adjustable for length because it was easier to built it to fit the frame. It is over kill because I used 3/16" steel but I wanted it strong. I did two things that make this different from most other mounts. First I made the brackets that attach to the bike frame adjustable to match the angle of the down tube and the seat tube. Second the rear mount longer to allow two mounting u-bolts to help eliminate the sliding of the mount down the seat tube. I hope you guys can use this information. here are the pictures.
Jim
Jim
