Hi eh!
Just got my China Girl ticking, it uses the stock exhaust and NTTC (NT?) carburetor with stock air cleaner, the square black plastic one. I'm using the stock 10-tooth engine output sprocket and 44 tooth rear sprocket.
Initially, it ran extremely rich. It wouldn't even fire at all with the choke on, when I took it off it fired right up. It four-stroked badly at all throttle settings and bucked like crazy at low speeds.
I started by taking the 0.028" stock jet and soldering it up, then drilled it with a 0.022" drill, which ended up giving about a 0.024" hole. The full-throttle running is now excellent and top speed is thoroughly nuts for a 44T rear sprocket, probably around 55 km/h (35 MPH) or so
Problem is, at low speeds and small throttle openings, it still four-strokes like crazy. I adjusted the jet needle to the leanest setting (C-clip at the top end of the needle) but it doesn't seem to have helped. At low speeds the engine runs rough, bucking like a bull and trying to run the bike at normal pedaling speeds results in four-stroking as the bike accelerates to a steady-state speed at around 1/4 throttle or less. The four-stroking only stops if I apply more throttle, but of course I end up taking off eh! Fuel consumption is, of course, higher than it should be at low power settings. At about half-throttle or more it runs great and the spark plug comes out at the ideal light-brown colour.
I want to be able to run the bike across a wide speed range, but can't use the small throttle opening range. I'm all out of adjustments! I'm currently using Castrol Super 2-Stroke oil at 20:1 ratio. Running less oil will only enrich the mixture, making the problem worse.
Any ideas? I'm surprised that adjusting the C-clip on the jet needle across all of the grooves seems to have almost no effect (I'm currently running it on the leanest setting, to no avail). Has anyone ever modified an NT carb to incorporate an air bleed?
Thanx!
Ian
Thanx!
Ian
