I purchased the Black Flying Horse motor from Bikeberry.com. It's installed. Fuel Flows. But I am getting no spark.
Things I have done so far:
Replaced Spark Plug
Sanded Contacts Inside Plug Boot
Desauldered manufacturers wires from Magneto and Sauldered new ones in
(This was done because the magneto was not givine me any readings from the wires, but was reading fine from the contacts) After replacing the wires it tests fine.
Replaced Ground wire in motor
Tested CDi and it was within BikeBerrys recommended Specs
The motor is definitely engaging.
I've tested for spark against the motor with the dengfeng sparkplug I received with it, and the NGK sparkplug I purchased to replace it.
About the only think I haven't done is replace the spark plug boot, and the only reason I haven't is because it's testing absolutely fine.
I've seen a few posts on this subject here previously, but none with a successful solution.
I'm hoping someone here may have found one and just not posted it. If not, is there anyone in Orlando, FL (Avalon Park\East Orlando Area) that would be willing to look at it. Or does anyone have a recommendation for a good shop I can take it to for professional inspection.
I'm at a loss. Bikeberry says theres nothing they can replace if the Magneto and CDi test correctly, which leaves me and my stepkid disappointed because we've got a motor that is just sitting on a bike doing nothing.
Any help you guys can offer would be much appreciated.
Thanks ahead of time.
Replaced Spark Plug
