Can someone check my math?
meerkatt
15
oxford
My motor peaks out at 9000rpm
my reduction box is 3:1
my final gearing is 6.5:1 (11/72)
so I make that 19.6:1 overall gearing
my rear tyre is 100/90/18 so circumference is 1.98m (yeah we are metric over here!)
So I get my 9000 reduced to 3000 at the box then 460rpm at the wheel for 911m/minute .... 55km/hour
Question is .... hows my math?
2nd question ... hows my torque gonna be?
All hail the gearing gurus!
bowljoman
370
Wa
you can check that here.
http://www.thebitstream.com/scoot/
Set the crankshaft-to-output-shaft at '3' for 3-to-1.
Set the input and output sprocket at the same tooth-count and select 2nd gear.
From there, figure your tire size in inches and select the engine sprocket and rear tire sprocket tooth-counts.
2nd gear is a one to one ratio at the transmission.
meerkatt
15
oxford
that calculator cant cope with my sprocket sizes! Halving both sprockets gets me on the chart but I doubt the accuracy of the results.
Anyone else?
5-7HEAVEN
2,661
240
Try this website, after converting from metric:
Index of /ratiocalc
Your calculations are correct.
meerkatt
15
oxford
thanks guys
How can I lock that scoot app into 2nd gear?
any idea how my torque will hold up through this gearing?
meerkatt
15
oxford
Found this
Gearing Commander: Motorcycle Gear Ratio Calculator for Sprockets RPM Speed Chain
Motorcycle app but easy to use and near infinite variations possible
best of all it confirmed my calculations!
BUT.... I still need someone with a brain to tell me whats gonna happen to my torque?
My understanding is...
torque at motor x gear ratio = torque at wheel
so my 3.5Nm x 19.6 gives me 68.6Nm=50.6lb/ft at the wheel?
is that enough to turn my wheels?
