I have about 150-200 miles on my new build and I just don't have much power and I can only get up to about 20 mph on a flat. I ran a 20:1 mixture on the first gallon of gas and then went up to a 28:1 on the second gallon, which I'm about done with. I know they run better after the first 200-300 miles but mine has not improved and I think it has gotten worst. here are a few details:
-new plug and wire.
-synthetic blend on the first 2 gallons going to full synthetic with a 32:1 from here on out.
-adjusted the e-clip because I fouled the first plug but then went back to the second from the top when I switched to the 28:1, plug looks good.
-checked the float and jet, looked good.
-cleaned the filter in the tank after the first gallon and changed the inline filter after the first 1 1/2 gallons.
-I had to add a extension tube on the carb with a 45 deg bend so it would fit around the seat post. the extension is 3-4 inches. could this be my problem with power.
-I've checked for air leaks with carb cleaner and its sealed up tight.
-new gaskets around the exhaust, carb bowl and manifold.
I was riding it the other day and it just didn't seem to have as much power as it did the last time I rode it, it won't pull hills as fast and it is just slower all around, and it never was that fast. this is when I checked the jets to make sure they didn't have any junk stuck in there, it looked clear. It has alway had a rough spot when you are riding it, it will run good until you get the rpm's up and then it gets rough. it will be rough going up a hill until it has to start working a little harder then it will smooth out some and sound good. The engine gets just a little bit of oil build up after a fair amount of riding, its on the front part of the engine I'm not sure where it is coming from. I know this is probably a little confusing but it is hard to describe what it is doing exactly. I kinda hope someone else has had this problem and will know what I'm talking about. If I left anything out you can just let me know. Thank you guys in advance.
-new plug and wire.
