Broke two heads in two runs??? Why??
johnsoma
21
Philadelphia
Hi guys,
I ran a new engine twice and broke two heads in less than 15 mins. It was a prebuilt motor from ebay. Only thing I did was paint the motor with black engine paint and cook it in the oven to set the paint. Any chance the cooking at 500degrees hurt something inside??
After painting and cooking of the paint I slapped it on the bike. It quickly began making a horrible metal knocking sound once I got it running. And then cracked two heads in the process. I thought it might be too long of a rod and So I tried two gaskets and it still makes the metal knocking noise. From the noise and the fact that i keep breaking heads it makes me think that the piston is hitting the head and thus cracking it. I am clueless. Also when I remove the head and just crank the motor over using the pedal with clutch engaged it will spin over very smoothly and make no noise at all which makes me think that all the bearings are fine.
I took pics of both heads and gaskets. For the pictures I put little arrows pointing out the cracks in the heads. The gasket when on feels like it is hanging in the cylinder a little, it is not smooth transition up the wall of the cylinder and past the gasket. Could that be it. Pics of that as well. This engine has been running for less than 15 minutes on both heads and has cracked both of them. All of the pictures and videos together can be seen on my Dropbox at the following link.
https://www.dropbox.com/sh/byd4nuoircso55s/AADZMnSqdVACPP7ZGXDpBHlOa
Someone mentioned a blown rod bearing? would that make this sound but also allow it to run as mine does? How hard is that to determine if true? and fix?
I am thinking about just buying a whole new engine. Thoughts?
Thanks for the help,
Mike
rogergendron1
882
2
woburn ma
the piston to deck hight looks stock and its far enough below level it should never hit the head.
your problem is over tightning your head bolts ! put them on too tight or tighten one all the way and not torqueing them in the proper pattern can and will cause the head to warp andwhen heated it will expand and crack
the knocking sound seems like a tottaly seperate issue... try turnning the motor over quickly with the head off and the jug torqued on with spacers by pedaling the bike with the clutch out with your hand wile the bike is on a stand of sorts and wile you do this listen carfully for the sound... if you hear knocking with the head offf then you have a major problem and i would pull the jug and check the piston pin needle bearing... it may be in pieces ! or you may have a bad case beaing that causes a woble enough to cause a hard knock
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Let me get this straight...
You baked your entire assembled engine in the oven at 500 degrees?
Wow. That's a new one.
Yes. That kind of temps will damage stuff in an assembled engine!
I don't even know where to begin telling you how bad an idea THAT was.
soup325
181
Canberra
I dont know what sort of paint your using, but even VHT engine enamel paint doesn't need that amount of heat to cure.
180°C = 356°F
http://www.speco.com.au/vht_faq.html
How do I apply VHT Engine Enamel?
A finish coat is only as good as the surface it is coating. We are frequently asked if VHT Engine Enamels can be painted over a primer or other old paint on the engine. To obtain the best results we recommend the parts be stripped clean of any old paint or primer. Wipe down the surface to be painted with grease and wax remover and prep with either Shellite or brake cleaner. For maximum adhesion and colour consistency we recommend applying VHT Engine Primer (SP148).
If the old paint is intact, remove any dirt, rust, grease, loose paint, etc and lightly sand to a dull finish. Wipe down the surface with grease and wax remover then prep with either Shellite or brake cleaner.
The topcoat is only as good as the base coat or condition of the metal. If the substrate gives way, the topcoat will follow.
Carefully follow the instructions on the back of the VHT can.
Paint the Surface: Do not use in temperatures of less than 21°C on parts that are less than room temperature. Apply VHT engine coatings directly to the surface to be painted. Apply a smooth even coat and lightly sand for a primer coat or spot prime. Hold can 12 to 15 inches away from surface and spray in one direction using long even strokes. Repeat the process in the opposite direction. Wait approximately 30 minutes before recoating. Excessive coating build-up is not necessary or recommended and will cause blistering and loss of adhesion. Apply only enough coating to color surface evenly. If touch-up or recoating is necessary after 4 hours, a light sanding may be needed.
Curing: VHT Engine Coatings will air dry in one hour and cure overnight. Baking for 15 minutes at 150°C and then 30 minutes at 180°C improves finish and provides a more durable surface for handling, resistance to salt-spray, chemicals and humidity. Curing may be accomplished by the inherent heat of operation, as encountered in engines, exhaust systems or by baking in an oven, infra-red, blow torch, etc. Starting the engine and running at idle for 15 minutes and letting cool can also cure VHT Engine Coatings. Restart the engine and run for no more than one hour and again let cool. If the engine is operating normally, this will bake on the finish. All curing must be done slowly.
KCvale
3,966
57
48
Phoenix,AZ
Hi guys,
Mike
Well, all the clutch grease is baked, all the fiber gaskets aren't happy, and I'm surprised the magneto solder connections were still good enough for it to even start.
Most of my 2-stroke engines get high temp motor paint (I like PlastKote) but I just do the head and all 3 covers not the block or cylinder.
I give them a couple coats outside and let the 100+F AZ sun bake it on all day and then cure overnight.
You can duplicate this with a Sun Lamp.
TIP:
A simple spray bottle with plain water is handy to spray off hot painted parts so you can handle them.
Do you have a torque wrench and know how to use it?
66cc book says 15# but I do mine to 20# cold 5# at a time in a star pattern, then tweak back to 20# again when it's hot.
I'd say just get another engine.
GasBike has un-assembled 66cc engines for $99.
http://www.gasbike.net/66cc-racing-engine-build-4028-prd1.html
You can paint individual parts until your hearts content before assembling the thing.
Good luck with it.
rogergendron1
882
2
woburn ma
wait you baked the WHOLE MOTOR ANDD NOT JUTS THE BARE PAINTED PARTS !!!!
sorry your motor is junk now .......... my advice is to take it appart and order a new motor and wile waiting for the new motor ..... port your jug and ramp and cut the piston and expand the squish band on the stock head and then deck it down for higher comp...
hey man next time srsly just paint and go LOL the motor gets up to 250 pluss deg wile running so it cures any paint all on its own wile you ride !!!
i use VHT high heat pait and then i just go for a long ride and wile riding i can smell it curing , when its done curing you wont smell it any more
