Well, had my first wipeout today...
justcruising
12
ontario canada
Was driving to work, and there was a bit of an icey patch that i was going around to avoid, and sure enough as i was approaching a non-busy intersection my brake line completely gave out. Luckily no cars were around me at the time.
The little ball on the end of the cable had ripped off as i pulled the brake lever, throttle went crazy (i guess because i tried to maintain balance or something) and landed right on my behind. Dented the gascan a bit but nothing looks out of the ordinary. Definately check your brakes often, because it can come down to life or death(for real).
While I have never had the brakes completly fail on me, I did have an issue similiar to yours. Riding a non-motorized bike on a steep hill one day my brakes came loose and I had almost no braking power. Only thing that saved me was a stupid trick that I used to use as a kid.
I jammed my boot between the tire and frame and used my shoe as a brake. It put me into a semi controlled skid, but it was better than nothing.
earl.k
242
2
PA! USA
i only wiped out once so far.. it was night time and i was holding a flashlight to see. i was going around a bend and just taped my back break. there was a lot of wet leaves on the ground and my tier slipped. i put it down as smooth as i could, and took most of the damage.lol i got road rash down my left side and my finger got smashed.
in your case your not to blame.. in mine, i can say i was being stupid.. but i now ride safer, and hope your first wipe out will be your last. good luck and safe riding:)
