help with killswitch
oldpot
159
MICHIGAN
my kill switch broke as seen in this pic,
as you see it as one wire that goes on the coil of the spring , now i got this new switch for it and i found out its got 2 wires , so i tried one at a time wiring the wires to the black wire and starting the engine and tried the kill switch and nothing happens .even wired the red/blue together and then wired to black and still nothing???.do i need to ground one of the wires ??.i never messed with these wires since i got the bike as they been working great since i bought it .
crassius
4,032
158
USA
the black wire on the CDI is ground try puting one button wire on black & other on blue
oldpot
159
MICHIGAN
the kill switch was already wired up like this when i got it , i even took the old spring and parts and took the new one apart and put old pieces into the new plastic holder and still did not work weird that , i will try again i might have put it in wrong way up as was dark outside when messing with it ,engine is a 49cc china girl about 6 years old .
oldpot
159
MICHIGAN
the black wire in the first pic is a ground wire i found out when i touch the black wire to the bike it stops the engine , i just now trying to work out why when i press the red button down it will not kill the engine with the same set up as before, i am guessing the spring it not going down far enough to catch the copper ring in the switch , i just have to keep trying .
crassius
4,032
158
USA
usually, a one wire button gets its ground thru the mount on the handlebar, while a two wire button gets its ground by attaching one of its wires to ground - you should try one wire to black & one to blue on CDI
