odd bottom bracket!
happycheapskate
1,989
Rockwall TX
I'll try to help you.
Does it look like this?
You may be able to look it up on Sheldon Brown's Bicyclopaedia. www.sheldonbrown.com
With today's wide-range freewheels and cassettes (34 tooth low gears!) even a cheap Shimano 6 speed freewheel would probably give you a very wide range with a single crank. Having a single shifter will help too because you need space for motor controls (throttle, clutch, switch).
