Welding Front Motor Mount
stuckonreplay
74
Frederick, Maryland
One of the screws on the front motor mount broke along with the hole during riding so I cant use the front mount. I need to weld the mount to the bike with a 1.2 inch clearance. Can someone give me some advice on this please?
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
Don't do it. The engine case is aluminum, the bike frame is probably steel. Even if the bike is aluminum welding the engine to the frame is a bad idea for many reasons.
There are alternatives. Take some time and do a little research here, use the search feature, keywords 'broken mount' and see what others have done. http://www.google.com/cse?cx=partne...gsc.tab=0&gsc.q=broken motor mount&gsc.page=1
In the mean time do not ride the bike using the engine with no front mount. The engine could break loose and bind the chain which could cause you injury and further damage to the engine.
stuckonreplay
74
Frederick, Maryland
I actually meant I was going to weld a bracket to the engine
