a meridian trike+motor+shift kit+8 speed
DA-zoocrew
16
University Place WA
I'm converting a schwinn meridian trike for my father,
who is 87 now and loves to ride his trike.
its not going to be for speed it will be built for
low end power. so it will be able to stop on a hill
and then start up the hill from a dead stop
with cargo.
I am putting a 49cc HuaSheng 142F with
a Sick Bike Parts 4 Stroke Shift Kit to a 8 speed hub,
CAN IT BE DONE??
I will find out, LOL
scratg
should prove interesting.
I am going to attempt
to not put it in the rear or in the basket. but place it in front of the seat tube.
the fuel cell will be behind the seat in front of the basket.
so far I think it can be done. it will defiantly be challenging to say the least.
.weld
I will start posting pictures soon.
flybytaco
Metal Molding Madman
Oct 17, 2009
1,170
8
seekonk MASS
anything can be done my friend. the meridian is a great platform to start with also. I plan on putting a hf 2.5 hp on mine and no shift kit with a 54t mm sprocket and adaptor the adaptor is going where the band brake is on the front hub and just gonna use the frt brake cause it will plip the bike over when squeezed hard enough
ocscully
373
Orange County, CA
Questions about some of the details? First: To get proper leftside chain alignment between the output from your 4G Drive to the 17t driven sprocket on the jackshaft. Was all you had to do was flip the 17t sprocket on the jackshaft as shown in Post #7 Photo #3? Second: At the bottom bracket you appear to be using a combination of parts from both the Grubee kit and the SBP kit? The crank arms appear to be from the Grubee kit, Which BB are you using the SBP or the Grubee? If you are using the Grubee, what was required to make the SBP front freewheel adapter fit the spindle? Or were you able to get the clearance you needed by using the SBP Cartridge BB with the Grubee crank arms? Third: Since it appears that you have made your mount essentially fixed and non adjustable in the frame, How are you maintaining the chain tension on the right side of the from the 9t driver to the front chainrings? Watching this installation is very interesting and I feel shows that the HS 142 CC 4G drive can be used with the 4-stroke Shift kit with a minimum of adaption/fabrication. As of now the SBP web site indicates that the motor and drive combination you are showing does not work with their mount. This is primarily due to the overall width of the motor and drive and also the alignment of the drive with the left side driven jackshaft sprocket. You appear to have solved both of these issues with a minimum perhaps no special fabrication required.
ocscully
flybytaco
Oct 17, 2009
1,170
8
seekonk MASS
how is the rim holding up where the axle ges thru on the drive side? i was noticing how cheesy that setup is when i was assembling my meridian
DA-zoocrew
16
University Place WA
ocscully
okay now i have it running and working out the small bugs i can give a little onfo
on how i did it.
1st: i cut the trans to crank chain adjuster off the trans, the L shaped
peace that sits below the motor mounting plate. i did this so the plate would sit right on the frame.
2nd: i welded the trans to the motor plate at the exact angle of the frame.
3rd: i found that in fact the motor sat to far to the right, so i slid trans/motor plate
as far left as it would go. that was exactly the amount needed to line up the
right side chain.
4th: i made extension for the U bolt mounts so the motor/trans can sit all the way left,
i used 1"x1/4" steel straps welded to the original mounts, after welding
i positioned the motor/trans mount on the frame and marked the
position of the U bolts, then drilled.
5th: i mounted the motor to the motor/trans plate and made up the motor to trans chain,
this is where the idea of no adjustment come in to play. the motor plate have elongated bolt
holes that give approximately 1" of travel, this is more than enough adjustment. also with that plate you have a
small amount of side to side adjustment.
6th: mounting it on the bike frame, this was very strait forward.
7th: running the chain from the trans to the crank sprocket, now if you remember i cut the adjustment
tab off the mounting plate so to make this work it was almost to perfect. the motor mount
plate is exactly the correct height and right next to the chain. so the easiest way to explain this
is look at an original chain tensioner that comes with a motor kit , turn it sideways and there is exactly the pattern for the side
of the motor mount. drill it exactly to the same size and it works perfectly. it slides 2"
and that's it,
parts i used
the crank & bearings from the SBP kit.
the pedal arms from the motor kit
motor plate from SBP
trans from SBP
chain tensioner from motor kit
i drove it today and worked absolutely flawless.
DA-zoocrew
16
University Place WA
yep the rear rims are very week and i have replace all rims with heavy duty rims.
with 10 gauge spokes, i also made inserts for the rear hubs.
they both are pinned, for left or right drive or both drive.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
Where did you source 10 gauge spokes just curious? I plan on building some custom wheels in the future.
TheDream
2
Illinois
How is the stability of the trike with the motor? I recently bought a Schwinn Meridian with the plan to put a 4 stroke motor on it. As I have been cruisin around motor free, I constantly have the feeling that the trike will tip on ruff surfaces. Perhaps it is just because I am used to the lean of a bicycle.
Cogswelln
207
Maine
i have a huffy cranbrook i converted to trike with a 2 stroke 66 cc and it handles fine sure if u take turns to quick it will tip, but i have yet to completely tip mine over i have had it on two wheels. Either way trikes are fun especially with a motor
