Man,
So my bike has been running very good in the past. 66 Skyhawk kit, three or four tanks past break in I think. I worked to make sure the carb was nicely sealed with no leaks and set at the stock second position. Somewhere between 27:1 and 32:1 with maxima oil. Original three point spark plug.
I knew the 415 chain was going soon, but just as I was headed to the bike shop with a new 41 chain, the 415 broke and took out a couple of my rear spokes.
Well my hand was forced to do the right thing. I got my rear wheel laced with 12 gauge spokes. Also had them break and join the #41 chain so no master link.
So here's where my problems begin. Got the new wheel and chain on and tensioned with the tensioner. And decided to put in a better spark plug. Got an NGK BP7HS.
At first, it seemed more smooth, but with less torque on the low end, a hint of bog here and there, but that seemed to work itself out. Also, there were a couple of little smoke puffs coming out of the exhaust on start, hadn't seen smoke since first breaking in the engine. I assumed the engine was maybe getting used to the cooler plug.
Then on the way to work today, everything was running just great. Stopped for coffee. Had the coffee in my cup holder, and I was running a little slower than usual so as to reduce splash and to avoid ejecting the cup. Then out of no where the bike shut off as I came to the stop light.
Since then nothing. I spent a few hours after work trying various stuff I read here from the "bogging" and "engine won't start" threads.
I pulled the plug, it was a little a oily on top of tan.
I took off the speed air filter, to see if it was clogged... it was clean. I took off the bowl to look for dirt, and also to verify that the fuel would flow through, but also would shutoff when the c clip was pushed by the float. Float looked good and didn't have any gas in it.
Tried a few starts, With Choke the engine would seem to start, but then would eventually bog out. Tried starts with half choke and no choke and a few variations on that. But when I came to a stop the engine would die. It just never started hitting, popping, the usual good signs.
Fiddled with the Spark some more and the boot broke. So I figured, better time than any to replace the wire and boot. Pedaled over to Pep Boys, asked for a 7mm copper core spark wire with boot. All they had was a 7mm lead wire and boot. Also it has "Suppression" written on the side of it. I heard on this forum that you should avoid that sort of thing, as it can weaken the spark on these bikes. That's all they had though, so I took it home and put it on. I also swapped to a B6HS, just in case the 7 was too cool for my engine or something.
So spent a couple of hours pedaling up and down my hilly street. Trying various ways to start it. I pulled the spark, its now kind of oily, but thats not a surprise cause I'd assume the engine not really firing up is causing that. With the plug out and touching the head, I rode the bike, and did see the blue spark. I don't know how strong it should be, but it did look a little weak when going fast, and at slower pedaling didn't seem to be sparking. But I'm not sure how its supposed to look. I tried what Norman recommended for flooded engines. Still no action. About two out of 20 attempted startups, when I switched out of choke the engine popped a few times like it was going to finally catch, but then it bogged down and died like the other times.
I took the cap off of the black cat, I did notice that a little fuel was coming out of it. I stuck my fingers in it, felt the honeycomb metal, didn't seem to be clogged, but I know when it happens it happens in that catalytic converter part that is welded deep in there.
So my next two moves.
1. Take off the muffler and go for a try. If it starts, then I'd assume the black cat is clogged. Not sure how I'll clean it but maybe I'll try carb cleaner. If that doesn't work I'll try to find a hacksaw, or maybe just buck up and order something else.
2. Get a 7mm copper core wire without "suppression" or "shielding" or "noise reduction". Something for bikes if possible. Hopefully Autozone has a better selection than pep boys.
If neither of those work out, I guess next up is to Solder the wires.
Then Kill the kill switch - Although how do you kill the motor if it actually starts... close the lines and run it out of gas? Is there a trick there?
After that start replacing stuff. The magneto, which I'm still kind of scared of going in there. Order a new CDI while I'm at it.
I know there is possibility that the magneto is out of sync with the piston, but would that just happen out of no where?
So I'm just kinda throwing out in one place all I've gleaned from your guys advice and expertise, but If there is anything I've missed please let me know. I had a good three weeks or so of commuting to work on the bike. I wanted to ditch the car with something better and learn something new.... bikes and engines are both new to me. It's been rewarding and fun, but my bikes got me beat down for the moment.
I'm addicted to these forums, you guys are all a brilliant blast.
