I just stripped out the 6mm thread in my head for the intake. The Loctite must have come lose. What would be the best way to repair it? I am trying JB Weld and letting it set up over night.
I wish more people would read this...I can't figure out how JB Weld got such a following here. It might have its uses...but I haven't found them yet.The JB didn't work. I will install a helicoil today. I think that will do the trick.
Heli coil won't work either as the hole needed to insert heli coil will need to be larger then the 6mm stud, and there is not enough material to support the stud.The JB didn't work. I will install a helicoil today. I think that will do the trick.
There are a couple of things that can be done..Yes you are right. There is not much room there for a helicoil. It turns out the hole was not tapped all the way to the bottom so I tapped it and got another 1/4" of thread. I applied Loctite and put the stud back in. It seems to be holding for now.
Dang I missed that (intake that is) I was thinking this was the front engine mount stud thread, another way is to go to a 1/4" 20. And yes a heli coil/time sert will work. Still you can remove the cylinder stud and drill and tap to it. Replace the cylinder stud, torque them down and install the intake stud/studs.This thread was asking about a stripped INTAKE stud/threads, not a front mount issue, I have hei-coiled the intake, there is enough room, at least on my motor, suggest you put it a bit deeper, leave about 1/4" of no threads, works good.
Mac
