OK here is the story
In June I got an 80cc kit and mounted it on my bike. It ran very well for the first 2 tanks. I had the gas/oil mixture at 16/1 because that is what the literature that came with the bike recommended. Then about 2.5 weeks ago I noticed the bike was losing power. Really slightly at first.
1. My first attempt to fix the problem involved increasing the gas/oil ratio to 32/1. This had little or no effect.
2. Second attempt was to change the position of the "e" clip on the throttle assembly. I moved it to the top location after reading suggestions on this forum. Again little or no effect. Moved it back to its original location.
3. I then cleaned the carburetor and again nothing noticeable gained. As a matter of fact the engine seems to be slowly getting worse.
4. I thought it might be a bad needle valve in the carburetor because on two occasions the engine returned briefly to its powerful former self when I closed the fuel shut-off valve. So I ordered a new carburetor from DAX o
5. Installed the new carburetor and tested bike. Still no power
6. Tried a different CDI and plug wire and saw no noticeable difference in the performance of the engine.
6. So now I have decided that its not the fuel or carburetor but maybe the spark.
7. I disconnected the black wire from the "C" that surrounds the magnet and sanded the connection. Again no noticeable effect.
SO here are my questions.
1. I tested the spark by unscrewing the plug from the engine head but left it connected to the CDI. Upon pushing the bike with the plug resting on the engine I saw some small sparks (just barely noticeabler) jump at the plug. Is this normal? SHould they be loud and more energetic?
2. How can one test to see if the plug wire is OK?
3. Could my coil be bad? How can one tell?
I really am at wits end with this thing. It was running great and then wham, its performance has gone south in a big way. I am really open to suggestions. Thanks for your suggestions on my previous posts. Unfortunately they didn't help.
Mike
Mike
