Hey there.
Iv'e been building this boartrack racer bike for a while now, and some changes have been made as it evolves. You guys can check out all the process at http://www.ratrodbikes.com/forum/viewtopic.php?f=54&t=33749&p=538665#p538665.
This is it's actual state:
Now I've got a problem!
I'm using a Lombardini 4 stroke 252cc engine and it has a conical engine shaft, not suited for the straight keyway of my centrifugal clutch.
So i'm stuck with a 11 teeth sprocket, from which I will have to run a chain to a 26 teeth input sprocket on a jackshaft. On the other end of the jackshaft will be my centrifugal clutch, runnin a chain to a final 35 or 44 teeth sprocket.
Here's a sketch:
Uploaded with ImageShack.us
The problem is that I dont know if the shaft will acquire enough rpm for the clutch to engage, since the 11t to 26t arrangement gives torque, not speed. This would be reached with the final 11t to 44t setting.
Could someone do the math for me and tell me what will happen?
If it does not work what arrangement would be advised?
Thanks a lot and keep it up.
Here's a sketch:
