Hello all, I completed my first build about a year ago. Since then I've put over 2000 miles on it and she's running strong. I started with a kit and and that motor crapped out on me pretty soon (about 300 miles or so, maybe less). So I went to the drawing board.
I purchased a 79cc greyhound from HF and made a motor mount out of scraps. Mounted the motor and salvaged what I could from the kit (gas tank, muffler, throttle grip, etc). I made a custom battery box to hold a little 12v UPS computer battery backup battery to power lights and a horn. Put a keyswitch on that box and wired it into my battery box so with key on i get juice with key off all electrical components off as well. I also wired that switch to the kill switch on the motor so with key off it can't be cranked.
I started with a centrifugal clutch and the kit sprocket on the rear wheel. It just wasn't geared right to get going good without burning up the clutch....not to mention I had already ruined 2 wheels because the chain jumped off and got into the spokes. I just couldn't keep everything perfectly aligned on my bike. After continuing to work with the centrifugal clutch and chain i ended up ruining yet another wheel.
Back to the drawing board again. I decided to forget about the chain and go with a belt drive setup. I then came across the whizzer motorbikes that I had seen from long ago and they were belt drive (didn't remember that until I found them this time around). So I took a 20in bicycle wheel, despoked it and mounted it to the spokes on my 26in rear wheel. Put a pulley on the motor and made a foot clutch (step on the clutch to engage the belt) and away I went. Made it around 400 or so miles this time and pop went the spokes. Those 14g spokes just weren't stout enough to hold up to the torque and vibration.
Back to the board one last time. I decided there had to be a better way. I took another 26in wheel and despoked it and thought about how to attach it to my 26in rear wheel. Welding it was my first idea but my wheels were aluminum so it would take a tig welder which I don't have and aside from that, those wheels are so thin I wasn't sure I could keep from burning through them. So I lined them up as evenly as possible and clamped them down. I drilled holes in about 8 different spots around the rims and then tapped them. I used little machine screws with locktite to attach them and keep them together.
Once I got my bike all back together I took it out for a ride and I've been riding to this day. So issues with this design at all. Well I take that back, after about 1200 miles on that design I did end up breaking another wheel. Not due to design but simply that the bicycle wheels aren't much and just normal wear and tear caused it to break the spokes. It could also be to the fact that the spokes may have loosened up some over time (i didn't keep a check on it so I'm not sure if that's what happened or not). Anyway, I just swapped out the wheel and attached my pulley to the new one in the same way and I was back in business.
I've got some pictures of it that I'll be posting soon and you can check out my youtube videos here that detail it fairly well.
First Video,
https://www.youtube.com/watch?v=BJL_q_jU3Vw
Second Video (completed build),
http://www.youtube.com/watch?v=P5xs0WMpGF8
First Video,
