Yes! Auxiliary transfer ports! Now, I'm not going to start celebrating just yet, because I'm still waiting for some parts before the engine can run. I provided a bunch of pictures showing the details. This type of modification has been done before and proven to work quite well. If it works in this engine has yet to be seen. Of course, I'm happy with an enlargement of the transfer ports, but I'm especially in favor of this kind of modification because it might actually make the engine more reliable. The reason I say this is because the auxiliary port is fed through a hole on each side of the piston, as shown in one of the pictures. Cool air and fuel will be flowing deep into the underside of the piston, cooling it and also possibly providing the wrist pin bearing with better lubrication. If this proves to be a winner, I will make spares which others may purchase. The cool thing about this modification is that it is possible for someone with a hand drill and a die grinder/dremel tool to do this particular modification. Although, I must warn that this enlargement of the transfer ports gets close to where the end of the piston rings travel. If the machining is not exactly in the right place, it could be bad news for the piston ring if the end is not always supported by the cylinder. There are two styles of 66 cc piston. This modification does not lend itself well to the GT-5 engines which use a piston that has a wrist pin hole location close to the piston ring grooves. The GT-5 piston does not leave enough room for the "feed hole". I don't know what else to call it. So, it's interesting, I guess the early engines use the low wrist pin location, and the new GT-5A and GT-5SR engines also use the low wrist pin location, so that's pretty good news if this all works. Well, of course I'll keep you all posted on this!!
-Fred
-Fred
