Not terribly hard to do- the drawback is that when you half the voltage on a heater coil, the wattage is cut by 4, not just half.
So it runs cool and takes longer, but fits in my bathroom inside the house and with no special 240 wiring- though I intend to use it on the circuit by itself in use. (The washer is out in the garage still, with another old dryer)
The motors actually usually run on 120 volts and the heater element only is wired with the 240, so there's a way to wire it up.
I've been chatting on automaticwasher.org as I did it and musing about the design:
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?51910_45
snuck in a picture of the old 66 build, to spread the love around.
I got that EXPENSIVE oil filter DELIVERED by the way, for my Sears lawn tractor- but my post about my difficulties and expense there was deleted and called a "corporate rant". I thought it was some pretty solid consumer reporting actually.
Below- my Kenmore Space Saver- now converted to 120 volts.
