I suspect this started happening as a result of my chain coming off and getting jammed in the drive sprocket last week. I am noticing my chain, does not have a consistent tension. It goes from loose to tight, to loose, as the wheel rotates. I have checked my rear sprocket, and its fine. I have found the tension changes directly correspond to the drive sprocket position. Every 1/2 turn, it goes loose, then 1/2 turn again, its tight. Upon visual inspection, it does have a bit of visible wobble. I took the sprocket off, and cant see any problems with the naked eye. After putting it back on the problem is still present. I really have no idea what to do from here. Do I order a new sprocket, and hope that was the problem? Hopefully nothing internal is bent. I don't think I posses the needed skills/tools/knowledge to dismantle the whole engine to replace something inside.
Please advise! Thanks in advance.
Farthom
Farthom
