This will be my first build. I’m a good fabricator and mechanic. But when it comes to bikes with motors im a newb. You guys look like you have a lot of fun with this hobby and I need a way to keep busy.
I have this pocket motor with the x1 trans that runs great, and this stingrays chopper. And I would like to marry the two.
The x1 trans has a 5to1 ratio with a 18 tooth drive gear. The rear sprocket is 20 tooth and crank is a 44 tooth..
I would like to free wheel the front crank, with extra gear and chain going to trans.
My big question is what size sprockets to get for crank and trans.
I would like speeds of 25 or so. With slight push or pedal at start if needed.
here is pic of trans i have and 12 tooth gear i found from this site.
http://www.pccmotor.com/49x1x2nipobi1.html
http://www.fancyscooters.com/item00298-scooter-part-sprocket-type-i-55-12-mm-12-tooth.html
thought i would order freewheel and crank sprockets from sick bikes. just not sure what size would be best. any help you pros can give would be appreciated.http://motorbicycling.com/images/smilies/duh.gif
ill post pics soon as i figure how to lol. ill have to do some reading on that
