What is the best spark plug out there? I have seen "3 PRONG HIGH PER FORMANCE JIXIN SPARK PLUG" and the "NGK B5HS SPARK PLUG", what do you all suggest? Thanks.
I found that plug at my local hardware store but it says it is for 4-cycle engines? Will it still work? And is 13/16inch the correct thread size?This question has been asked a million times, but I am glad you asked it because my opinion on the subject has changed since I answered this same questiion last. I was a fan of the NGK B6H until I installed a new E3.10 spark plug a couple weeks ago. The NGK plug worked great at idle and at top end and was 100X better then the junk stock plug, but I always had a spot in the middle that was a bit on the fat side and could be just a tad rough. After installing the E3.10 spark plug it runs fantastic at all throttle positions and now my cheap China girl almost has the feel and crispness of a quality Honda.
My bike also runs lights directly off the white wire and my engine will start the very same no matter if the lights are turned off or on. I also don't notice any type of surging lights at various throttle positions. Right now...for me, everything is working just like I would expect it to, smooth and consistant. Thats been my experience and yours may not be the same, but from here on out I think it is the E3.10 spark plugs for me.
Like this?They only make that plug in the one thread size I believe. If it says it is an E3.10 it will work great.
Thanks for this info...This question has been asked a million times, but I am glad you asked it because my opinion on the subject has changed since I answered this same questiion last. I was a fan of the NGK B6H until I installed a new E3.10 spark plug a couple weeks ago. The NGK plug worked great at idle and at top end and was 100X better then the junk stock plug, but I always had a spot in the middle that was a bit on the fat side and could be just a tad rough. After installing the E3.10 spark plug it runs fantastic at all throttle positions and now my cheap China girl almost has the feel and crispness of a quality Honda.
I just ordered one at Advanced Auto, picking it up tommorow.I happened to be at Home Depot today and picked up a E3.10 spark plug. One good thing for sure, seems you can get 'em about anywhere...
Tiny little buggers aren't they? Being short could be helpful to provide that extra little space to get the stock plug boot on a bike with a small frame...
Haven't had a chance to install it, weather is supposed to take a turn over night, so I'm not sure when I'll get a chance to check it out....
If I went with an iridium plug (which only come in the long versions), would that help me with power?QUOTE]
I can't say for sure as I have no personal experience with the NGK iridium plug, but I have read alot of good reports on them from people using them. The only thing I can say is that I just can't imagine anything working better or making my engine work happier then the E3.10 plug I am using. If the iridium plug did work as good it is a bit more expensive plug and like I said....it wouldn't suprise me if it performed as well, but I would be really suprised if it performed any better.
Sorry to hear you had different results with the E3.10 then I have. My bike starts so easy with the E3.10 plug that you can almost just start it with your mind.LOL Of course I like the NGK plugs as well...its just that my experience was about the same as yours, but in reverse.I finally got a chance to audition the E3.10 spark plug today in my Grubee GT-5 66cc...
First thing I noticed is a bit of a hard start, and the motor didn't run as well while warming up. Once warm the motor ran pretty good, very smooth, but the overall performance was a bit less than I was used to with the NGK BP6HS plug. I took a good long ride, let her warm up fully and get a feel for the performance with the E3.10 plug. I switched back to the NGK BP6HS plug and the motor started super easy, which is what I had become accustomed to. The motor ran better cold and also better when warmed up, so I am gonna stick with my NGK BP6HS plug since my motor seems to like it. Both plugs were gapped at about .028 BTW.
The motor did run very smooth with the E3.10, it's definitely much better than the plug(s) that come with the kits, but overall performance was better with the NGK plug. Just figured I would add my feedback to this thread now that I have compared the two plugs.....
