The frame I ordered from Bicycle Designer arrived on May 4, 2012.
I ordered the Bicycle Designer Z 2 Stretch Cruiser Frame with faux tank.
No matter which engine you choose for this frame be it a 2-stroke bicycle engine kit, or a Horrible Fright 99cc predator or the Horrible Fright 212cc, or my favorite a Honda Mini Trail 50 clone engine, these frames with the square bottom tube make motorizing so much easier with the Harbor Freight or the Honda Mini Trail 50 clone engines.
So many things to do to get this build started, first I'll weld in the 6" X 12" steel plate also known as a skid plate.
I'll be changing out the rear drop outs, and sealing the tank, adding the fuel filler bung & fuel petcock!
I haven't decided on the forks I'll be using, what forks would you use for this type of build?
Still have much more work / modifications to do to complete this build!
Checkout my photobucket page for more pic's of this build if you like here's the link below:
http://s978.photobucket.com/albums/...ke Honda Motor for Motorizing StretchBicycle/
Here's a couple pic's to checkout below:
The last pic below shows the four bolt holes that will secure the engine to the steel plate that I will weld to the square bottom tube!
Peace, Crazy Horse.
Peace, Crazy Horse.
