2-speed for ht bicycle engines?
Moto
403
15
18
San Francisco, CA.
Re: 2-speed for ht's?
That would be rad. Ive seen people run 2 sprockets in the back (no jackshaft) but never that. I would think it would stick out a little just like a pull start
maniac57
Oct 8, 2011
4,484
22
memphis Tn
It would take some custom machining to make it work, but I see no reason it couldn't be done....except that $1100.00 thing of course.
These work by having a second drive and pinion gear on the same shaft with a centrifugal arm that flies out and engages the next gear at preset RPM's. The second gear runs on a one-way bearing that lets it take over the shaft when engaged and slip when rpm's are lower.
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
HEY AFTERMARKET!
We want something like this that fits the chinagirl. If you could make it fit under a stock thickness clutch cover, that would be even better...
http://www.ebay.com/itm/New-King-mo...adio_Control_Control_Line&hash=item1c2ff4ef35
Affordable Go Karts has already tried a 2 speed go kart set up
on their 99 cc Predator race bike.
They decided that it added complexity without much performance gain
so they went back to a single speed jack shaft.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Okay. Pi$$ in my cheerios.
I want this to work SO BAD....
I had an RC truck that I installed a 2-speed on and that thing RIPPED!
Of course, being a .12cc glow engine,
it had about three times the power of a chinagirl. :)
biknut
6,631
409
83
Dallas
The main problem is going to be the cost. It's more than a whole china girl motor. Another problem is it would probably make a motor bicycle turn into a motor vehicle in most states, because it would likely become classified as self propelled.
