Hi,
I am looking for answers to a problem with my Hua Sheng. I have it paired with a firebelly transmission. When I first installed it the idle was pretty smooth and the bike topped out at 35 mph on the flats. There were some initial issues with the firebelly transmission which caused it to break it's primary chain a few times. That issue has been resolved with better sprockets. The problem with the engine occurred the last time the transmission's primary chain broke and jammed, and caused the engine to stop abruptly. Now it seems to have less power, idles roughly and only makes it to 28 mph. I have since replaced the spark plug, adjusted the valves, inspected the carburetor, and changed the oil but with little improvement. There is also a new buzzing vibration that occurs around 21 mph which I don't remember being there before. My question is, what could cause this sudden drop in performance? Could the cam gears have skipped a tooth and changed the cam timing? Could the crank have gotten twisted and caused a shift in the cam timing while also causing the new vibration? Any other ideas?
Also, is there a service manual available in case I want to start disassembling the engine for a closer look? Maybe I should just buy a new engine? Any advice is appreciated. Thanks.
