it's all wobbely! my pipe that is, help for fix?
PatMcLJr
29
earth
I was out my 2nd test ride, a little longer.
Seemed like everything was humming along. The she started sounding lose up and vibrating. I limped back and found the chain tensioner, kinda expected that, but the I saw my pipe danging and wobbling. I let it cool of and took the pipe parts out of it. It looks like the welds broke inside that hold the header pipe to the muffler part.
Help! I don't weld or know a welder. Can it be soldered? Braised with some kind of propane torch? A special, cheap, clamp? Any ideas other then welding?
Thanks,
Pat Jr.
Would this work?
- J B Weld Stick
Maybe some good old JB Weld?
J-B Weld Company - J-B WELD Product Information
PatMcLJr
29
earth
Hello Bikeguy Joe and Cabinfeaver1977,
Thanks for the replies. OK it wont hold up. I think I'll try the wire and JB Weld until I can get a pipe for it.
Thanks Again,
Pat Jr.
HoughMade
623
Valparaiso, IN
I've held my tongue long enough....sorry if I offend.
JB Weld is a cheap, cheesy fix if it is a fix at all. It will not work for this application, as Bikeguy said, and unless it is just used as a filler, it is, at best, a temporary band aid.
Brazing will work, but use MAPP gas, not propane. However, if it is a chrome part, enough heat to braze will discolor the chrome quite a bit.
PatMcLJr
29
earth
Thanks for the tips!
Hey HoughMade, don't hold your tongue, let'r go! I need all the tips I can get, but on the cheap side please! Where can I get a stick of the brazing rod?
Thanks,
Pat Jr.
Forbisher
119
Orange County, CA.
Thanks,
Pat Jr.
2nd test ride?
How old is your kit?
Where / who did you buy it from?
Sounds like your broken pipe should be covered by the sellers warranty
Did you get a warranty?
Is there a stub on the muffler left?
Chrome?
black?
Catalytic?
Posting a pic would be helpful for a temporary fix
Where on earth are you? :D
Good luck on getting back up and running ....
PatMcLJr
29
earth
right now I'm in Louisville, KY
I got some Brazing rods at HomeDepot and I used some map gas, the yellow bottle.
I heat, and I heat, and I heat, and I heat, and I heat, and I heat, it wont melt and the pipe wont turn red. I must be doing something wrong.
Is this the right rod to use?
It's just the regular black pipe. The tack weld or sweding:confused: came loose inside where the header pipe goes into the muffler part.
Thanks tons guys,
Pat Jr.
Ocean7
15
USA
Hey Pat Jr.,
Sorry to hear about your muffler. I have learned that when dealing with these kits … expect the unexpected.
If I were in your situation I would probably just order a new part instead of using up time, money and effort for only for a “temporary” fix. It would be cheaper in the long run.
Good luck, :)
PatMcLJr
29
earth
Hummmm OK you guys give good sound advise, best I listen and take it.
Hello, Dax ...
Pat Jr.
Yea!
my neighbor siad he could weld it, he put a couple of tack weld on the outer edge and it seems like it's pretty sturdy now.
