Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Tandems, Trikes and Recumbent Bicycles
Motorized Tandems, Trikes and Recumbent Bicycles Trikes (tricycle) and recumbent bicycles can give the ultimate in comfort for cruising on long trips or just around town. Ad an engine and they will really turn some heads.
Old 03-22-2015, 10:00 PM
Intrepid Wheelwoman's Avatar
Intrepid Wheelwoman Intrepid Wheelwoman is offline
Default Re: A Hybrid Stirling Trike
Yes C-S I'm going to setup the cooling system as a thermo-siphon system with the copper fire extinguisher casing as the water reservoir. I thought about using a radiator instead, but I think a reservoir type cooling system should work fine as well as being a lot more robust.
Because I haven't built a Stirling engine before I wanted to give it a try. If it doesn't work out then it can be used to run a fan in my workshop which the vertical gamma type are very good at doing.
I suppose this project is about the joy of building something from collected bits and pieces and if it all works then that's a bonus. Producer gas and other species of engines are quite possible as well, but we shall see how we go.
Money can't buy happiness, but it can buy chocolate which is almost the same thing
Home of the Kotanga Tramway.
MotorBicycling.com
