Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Tandems, Trikes and Recumbent Bicycles
Motorized Tandems, Trikes and Recumbent Bicycles Trikes (tricycle) and recumbent bicycles can give the ultimate in comfort for cruising on long trips or just around town. Ad an engine and they will really turn some heads.
Old 12-27-2014, 10:20 AM
racie35's Avatar
racie35 racie35 is offline
Default Re: New Project
Any updates?
Old 12-27-2014, 10:21 AM
racie35's Avatar
Do you have pictures of your installation?
Old 12-27-2014, 09:40 PM
livesteamfan's Avatar
livesteamfan livesteamfan is offline
Not really. Due to mine and her work schedules, me and my wife are not home at the same time during daylight hours so I can't take pictures with her phone. I will say that I made the swap from a belt to a chain on the secondary drive and it does seem to work, but I have not yet ridden it. I work a full week this week without a day off, so it may be awhile before I can ride it and get any pictures in.
Out of all the things I've lost, I miss my mind the most.
Old 12-27-2014, 09:48 PM
racie35's Avatar
Jokay...keep us posted please
Old 12-28-2014, 02:06 PM
56cc 56cc is offline
Ditto to that, sounds like an interesting project.
Old 01-01-2015, 06:18 PM
I ended up getting it moving and it was working quite well until the little gearbox broke. I opened it up and all the gear are plastic; at least what's left of them. So I went ahead and ordered a clutch and some bearings and I'll be going that way. I just need to wait for one sprocket and get a rod turned down so it fits in the bearings I bought. It makes perfect sense that a rod sold as a 5/8 diameter wouldn't fit in a 5/8 bearing I guess. 30 seconds on a lathe should fix that.
Old 01-01-2015, 07:36 PM
racie35's Avatar
I'd love me to see your complete setup ...to offer more help
Old 01-01-2015, 08:01 PM
Well, from the last set of pictures it hasn't changed other than going from a belt to a chain drive from the wheel to the lawnmower gearbox and I moved the tensioner to the belt that runs the transmission. Like I said, it worked quite well until the plastic gears in it gave out. Being without a camera and having to have both me and my wife home during daylight hours so I can use her phone to take pictures is really hard to do. My cell phone is just a phone and nothing more. I barely like having the stupid thing, I'm still using a rotary phone at home. But, I'll try to get some pictures as I change over to using a clutch and jackshaft.
Old 01-06-2015, 06:18 PM
Okay, whole new setup since the plastic gears in that little transmission stripped out. I've gone with a Max Torque or whatever clutch along with a jackshaft. It's a 10 to a 32 and then a 10 to a 44. Full throttle feels about 15-20mph and it is extremely torquey. The 32 tooth sprocket is completely JB Welded to the shaft because I had to drill and tap it to put a set screw in it and I didn't have a tap long enough to do that, but it is holding extremely well. I'm going to do the same to the 10 tooth because the set screws keep coming loose. And I know the whole thing looks like it's twisted to one side, but that's just the pictures. But, it is working both under power of the engine and the pedals, now I might give it a paint job and maybe even new tires.
Old 01-08-2015, 07:51 AM
Dulcijo Dulcijo is offline
Here is my setup. I went from 10 tooth clutch to a 24 tooth input jackshaft to an 8 tooth output jackshaft to a 60 tooth wheel sprocket. I get about 22 mph comfortable top and it pulls real good and cruises good at about 17 mph. It is powered by a 3hp 4 cycle.
MotorBicycling.com
