Missing chain tensioner and band-aid fix.
bluegoatwoods
1,581
6
Central Illinois
Going to work yesterday I thought that my pedal drive felt just a bit strange.
So I came out during the day to adjust my rear wheel. I found that the chain tensioner roller was completely missing. No sign of it. After thinking about it for a bit, I came up with a decent substitute.
It's a machine screw. I didn't even bother to check size or length. I suppose it was an inch and a half or so. Double-nutted to the chain tensioner bracket.
Then on the chain side I filled the shaft of the screw with washers that fit loosely on the screw. They'd do the same thing as a roller would. Double-nutted the end to hold them on.
I only had to go about 12 miles before I could get my spare roller on there. But it worked so well that I think I could have ridden indefinitely.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
I have a customer who replaced his with washers and a sleeve. Does not spin at all, the chain just slides over it and it's been working perfectly for over a year. Loud but functional.
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
I've seen many non-rotating tensioners in industrial applications. Just keep it well lubricated and not too much chain tension and they work well. I've seen them made of steel, brass and plastic/nylon/teflon.
crassius
4,032
158
USA
most important job of tensioner is to make the section from tensioner to rear sprocket perfectly centered
