Has anyone done a check or seen a Kent Del Rio 26" bicycle? I have seen them for about 130.00 and was wondering if they are a strong candidate for a engine? Look good anyway. gphil
even if it is poorly assembled at wally world you can easily straighten all that out and true the wheels and make a good build out of it, the tank issue can be got around also if you have the tools to do the fab work.Good to know info. Seems like a good bike but guess not. Sort of want to do a stretch cruiser for kicks then another Schwinn type frame. Thanks again. gphil
I have several 3 speed coaster hub wheels but they're to big to use a Rag joint sprocket mount or the manic clamshell type also, in my opinion the 3 speed coaster hubs are more trouble than they would be worth to use on a motorized bicycle unless they are being used with a shifter set up and even then I'm not sure how well they would hold up unless someone was very easy on them, but that just my opinion.3speed coaster brake wheel? Prepare to fork over good money, they do exist, but they are rare & not at all cheap! Good luck Greybeard.
That should make a nice riding bike, I'm a bit leary of the narrow tires myself because I do some much rough road riding on the dirt alot, but several people use the 700c tire and like it a lot, I think Nashville Kat uses them and thinks a lot of how they work.Hey, Thanks for the input. I've had my fill of chain alignment problems. I may just opt for the Schwinn Admiral and put a SR Suntour XCM fork on it.
We shall see....
Absolutely right, you'll never get a proper kit sprocket mount on a 3-speed hub like the popular Shimano Nexus.I have several 3 speed coaster hub wheels but they're to big to use a Rag joint sprocket mount or the manic clamshell type also, in my opinion the 3 speed coaster hubs are more trouble than they would be worth to use on a motorized bicycle unless they are being used with a shifter set up and even then I'm not sure how well they would hold up unless someone was very easy on them, but that just my opinion.
Map
I do however find internal hubs for shifters far better than derailleurs for many reasons.
The biggest and most glaring reason is the final drive chain size and function.
I generally run 410 HD Z-chain but you can even run 415 if you want.
It is just one fixed sprocket to another.
A sprocket array however needs ever thinner chain depending on sprockets and the chain is forced to move from to another under power.
Dandy for human power, not so dandy when pedals have 100's of times more force with a motor power.
The trick is to learn how to operate a shifter and they will hold up fine, I just find the internals to be far more reliable as after a couple dozen 3-speed shifters and a couple of dozen 7(8,9)-speed shifters I have never seen a 3-speed fail but had several derailleur failures from broken chains, a broken derailleur, to bent gears and and even a bent axle.
Way off topic regarding this Kent bike, just reaffirming what map said, don't go with an internal geared hub if you are going direct drive.
I don't know about the Suntour but Sturmey Archer has been making quality hubs for years. Good enough to still be good after 40 years? Most likely be OK if wasn't left out in the weather.KC
Ill be off topic hers a little also and ask since I know you have a lot of experience with shifter bikez and the 3 spee hubs, do you think one of the Sturmey Archer hubs from the 70's will hold up OK?
I also have a Japanese made Suntour 3 speed hub on a nice old womens Free Spirit bike I have wondered about.
Map
Not that expensive, $123. for a matched 26" wheel set with a 3-speed Nexus coaster brake and twist shifter.Superdave; said:3speed coaster brake wheel? Prepare to fork over good money, they do exist, but they are rare & not at all cheap!
I have dozens of shifter builds with 14's and no issues.I have heard of folks running 14 gauge spokes with no problems, but I'm a little concerned because it sounds like he's gonna jackshaft his on a geared hub.
