I have a Grubee Skyhawk 80 cc with a high performance carb. I know
very little about gas bikes, so I need some help.
I started using it about a month ago, and it was working ok. It didn't
go as fast as I would've like but the manual said it's gonna get
faster after break in.
Then I noticed that after I stopped at a light, the engine took a long
time to accelerate to top speed. But it would fire up to top speed
immediately when I took it out on the road to start the ride.
About a day or two later, it would start bogging down and would not
run at all.. At first, I thought I put too much oil in, but then I
noticed something curious. After I had pedaled for about 30 minutes
with the tank petcock shut off, if I suddenly engaged the engine, it
would start running, and eventually screaming, really taking off. Then
it would sputter out. When I noticed this, I quickly turned the fuel
petcock on, and then motor would continue, then cut back out again.
Two questions: why was I losing acceleration at the light, but not at
the very start when I engaged the engine? What was the cause? And what
about this thing with the fuel supply?
