Tanks: old vs new, how similar are they?
itchybird
316
6
SF Bay Area.
Seems I never run out of questions....
The new NE5 style tanks look pretty close to the pictures I've seen of the vintage Whizzer tanks, but how close are they? Same size and shape, or totally different?
Rich
Hi Itchybird,
Vintage Whizzer tanks were made in two styles. The tanks used with the "H" motor [1946 to May 1948] had smooth sides, were pewter [silver]in clolor, and came with yellow decals. The tanks used on "J" and later vintage motors were embossed with the Whizzer logo and available in several colors, most popular was Whizzer red [Maroon]. All vintage tanks had the brackets brazed onto the tank and had both sides of the bracket with a curved design to fit the top bar on the bicycle frame.
The new edition tanks were also originally smooth sided, but the brackets were flat across the top to fit on a flat mount welded to the new edition frames. Later tanks hade the Whizzer logo embossed but still maintained the flat top mounting bracket. Just before production stopped the gas tank was offered in a larger version.
The vintage and new edition tanks held approx the same amount [5 quarts], however the rare larger tank was rated at 1.7 gallons. My Ambassador has the larger tank, but due to the mounting position it holds abount the same amount as the 1.2 gallon tank before it overflows.
Have fun,
The new tanks are similar, and have been used on a few Whizzers where "keeping it original" wasn't important.
It is difficult to locate the correct fuel shut off valve for the new edition tanks, but can be done.
The tanks are very similar and hold about the same amount of fuel.
Have fun,
